@Wildthing - seriously nice I have to say! I will be cutting the ailerons as I am going four servos on mine! (I am on the road this week so you look like you will be well ahead shortly)!
It looks like you added the tapers post glueing - I tapered then glued the tapers together - no right and wrong here just innovation!
Yes, laminated the plates together first that way if you are out of alignment even a bit you can sand or trim the edges to match.
Another quick sanding to the LE now , wings look not to bad. As is they weigh in at 40gr and 41gr so one needs a tad more sanding
I am debating whether or not they need ailerons, more weight
@flyboa what is your thought?
I am also debating if I should use iron on covering, more weight but it also will add some good strength . If you paint or use packing tape you are adding weight anyways.
I will be at a standstill shortly until the arrow shafts show up. I also have to locate a micro rx for my FlySky TH9X , I am sure my 6 channel ones are going to be to big.
