bracesport
I tossed the ailerons away (easy to make new ones) and started stripping the foam wings - the Adams board is not so friendly for paper removal so I tried both the dampened cloth and then some denatured alcohol on the old ailerons, but it did not really do the trick - in the end, I managed to peel the paper off making sure to lift and peel evenly - in some places I needed to cut through the paper to make strips about 4cm wide which peeled easier - phew!
@flyboa 's fuse/tail is about 70g all-up-weight so the to go under 200g (maybe 180g) my wing needs to be around 100g - so far the weight drop is almost half and I plan to thin the foil section to 5-6% so the weight will drop a bit further before I re-skin the surface (adding weight)!
