Hi everyone.
I'm looking for a little bit of help and advice. I've read a number of good threads on this forum, so thought I'd join up.
I'm currently planning to build a balsa/ply/spruce 1/6th scale Bristol Scout biplane. I have got two sets of plans, one is 1/3rd scale and another 1/6thscale. I'm trying to build as close to realistic as possible and the 1/3rd plans are a lot closer to real than the 1/6th plans. I'm planning on downsizing the 1/3 plans to 1/6 and halving all dimensions and thicknesses, but I'm worried of any problems this may cause. As I understand it, getting smaller improves relative strength and rigidity but decreases lift and performance for the given weight. Therefore, should I be aiming to also reduce weight/strength as much as possible, so that overall weight is less than 50% of original? For the record, this is not going to be flown hard and stunted, so I don't mind a slow flyer. Also, I'm going for a glow engine to be as light as possible.
Any pointers would be greatly appreciated!
Thanks in advance,
Dan
Thanks in advance,
Dan
