Edge 540
Hi all, has anyone built the EDGE 540 from plans? I suspect the measurements are not exact. I have to say that I use 5mm foamboard and Sponz plans are based on 4.7mm fb. Greetings
I have built one from plans. Used Adams fb from the Dollar Tree. It came out great. I plan to build several more before flying season starts. I did make some modifications, making the build far easier. Eliminated all of the tabs, reduced the part count and fancy cuts that would be too tedious by hand. The most difficult part is the cowl, with a scroll saw, you can cut multiples at one time.
