Cherokee996
Hello All, new to the forums, second post here.
I just finished my first foam build, a Simple Storch a couple of days ago. Still waiting on the electronics (the motor I've been eyeing is currently out of stock) but weighted glide tests are proving that this airplane certainly has potential. I've read quite a bit in the past few weeks about RC aircraft and have come up with a few questions. I'm hoping someone can shed some light on it.
I came across some info on vintage Cox Engines and it appears that there is a company in Canada that still sells brand new Cox engines. What confuses me is the comparison between gas and electric power plants and the specific notation of how these engines are labeled.
Take for example, the Cox .049. Doing a little research, I found that you can supposedly multiply the displacement by 2000 to achieve the equivalent wattage. Does that mean that a Cox 0.049 engine will produce only 98 watts?
My next plane is most probably going to be the FT Spitfire. I plan on reinforcing the foam and gas/oil proofing it as well. The recommended motor is about 350 watts, so would the approximate gas counterpart be a 0.18 cubic inch engine?
Any help is greatly appreciated!
