So I ran into an issue with my Aircruiser and not sure if I have a ESC/BEC issue or an issue with the new Rx. I recently got Frsky Taranis Qx7s and a RX8R pro reciever. While at the field I was getting things set up and had the system reboot twice. I am running with 5 channels. Motor, 2 aileron, rudder, elevator. I am using the flite test c pack radial and 35 A esc. Apparently the esc has a 5v/3a BEC so how do I know if I have a BEC/ESC issue or a bad Rx. I guess I could set it up with the rx6r which was working on the simple scout. Is there a way to see the draw of the motor and servos? Hopefully I can recreate the issue to help understand. Any suggestions? Thanks.
