EZ P-51A Apache Chuck Glider
EZ P-51A Apache Chuck Glider V1
Please log in to download
Sly Fox
Hmm did you put it on fit to page or actual size it probably won't change the way it goes together!
Ok tried reprinting the single sheet and made sure it was set to actual. It did cut off just a bit. So I must have had it set to "fit" the first time. FYI, on that setting it reduced it to wingspan of 11 1/2" and fuselage length of 9 1/2 " - so about 1/2" shorter wing and 5/8 shorter body.
GrizWiz
Thanks for the help! Now you should start building!
Sly Fox
Actual size for both. The poster centered it across the 2 pages. I'll measure it and tell you the difference.
FYI there was about a 1/2 " difference. However I did reprint to check and I must have had it on "Fit" as the 2nd time it did cut off a little bit.
Sly Fox
Finished it and got it all "painted"...
ennobee
Hmmm. This brings back memories. My brother and me, back in the eighties got a hand on several sheets of about 1/8 in. (Actually more like 3 mm) styrofoam. I believe they came with a box of mandarines. Anyhow we made a whole menagerie of WWII gliders. In particular the Mustang was one of our favorites. Yes, it flew real sweet and most importantly you could throw it at each other without having to worry what would happen if you hit. So yes, glad to see the old Mustang again. Congratulations.
tetraodontoxin
Printed this to do as a family project this weekend, is there a specific spot you placed the penny on the body? Like how far back from the spinner detail line should it sit?
GrizWiz
I am not sure of the exact placement as I designed this a long time ago. I suspect that I put it about half and inch from the tip of the nose. I may be incorrect and you may want to experiment with different placement until you get it flying the way you like.
ennobee
I don't know the exact location on the plan, but when I built chuck gliders, I always tried to Ballance them on two fingers of my hand. As the P-51 is a low wing monoplane you might have to hold him upside down and then move the penny back and forth (with a piece of plastic tape to hold it in place) until you can Ballance it on a point at approximately ¹/3 of the with of the wing (from the nose up)
29rturner
I made a skin for your glider grizwiz its prety good if i do say so myself its version 1 but version 2 will be more detailed :))
