EZ-Skilpad
EZ-Skilpad 1.2
Please log in to download
AgentC
AgentC submitted a new resource:
EZ-Skilpad - The ultimate slow flyer. Also, the ultimate glider... As one plane. Is this a possibility? Let's try
A custom design for Flite Test's '2023 Red Bull Flutag Design Challenge'.
Throw the plane with no power, have it glide, then add some throttle and bring it around again and catch it on the glide back to you.
It's like playing fetch with your dog. But, you know, without needing an actual dog...
Read more about this resource...
AgentC
Build Log:
  1. Print out and stick the plans together.
  2. Cut out the parts. Bevel the wing's leading edge (except where the fuselage meets).
  3. Remove the paper from the top of the wing. Glue the tail Vertial stabilizers/fins at 90°. The plans have a double-bevel to create a cleaner outside edge, but you can also just go the usual FT cavity removal technique if that is your preference.
  4. Add tape to the anhedral folds on the top side of the tail for reinforcement.
  5. Remove paper from the remainder of the top and bottom of the wing section now.
  6. Add tape on the bottom side where the dihederal lines are. Glue and set the wings (at 15°) using the guages, tucked under the wing, up against where the crease is.The middle of the fuselage should always be flay on the table.
    PXL_20230728_004815006.MP.jpg PXL_20230728_004819370.jpg PXL_20230728_004829030.jpg
  7. Put the wing aside for the moment. Grab the fuselage and remove the cavities (if you haven't done so already). Leave the powerpod cut section alone for now. We'll cut it out later.
  8. Add the doublers
  9. Glue the sides of the fuselage where the powerpod will eventually go.
  10. Glue the back section next, and then ensure the bevel is flat with the angle of the fuselage.
  11. Glue the nose, section buy section.
    PXL_20230728_010445929.jpg PXL_20230728_010527639.jpg PXL_20230728_011136831.jpg
  12. Now that the fuselage is done, cut out the tab for the Power Pod. If you're making only a chuck glider, instead of cutting out the whole rectable, create a tab so that you can add weight in the nose.
  13. Check (dry fit) the fuselage to the wing, then glue it in.
  14. Set the anhedral on the tail section by using Guage 2 and setting the fuselage flat on the table.
  15. Chuck glider complete! The plane balances with a 350mAh Lipo (about 10g) in the nose, using the doublers for friction fits)
    PXL_20230728_012654082.jpg PXL_20230728_012702060.jpg PXL_20230728_012709971.jpg
Add the EZ Pack:
  1. Before installing the motors, make sure you have the props in the correct configuration for a puller. (swap props and insert them 'backwards'). Install the control board to the power pod adapter/holder.
  2. Tape the motor mounts into place. White/black wire to the right, red/blue to the left and then feed the wires in through the slots in the fuselage (inder the wing)
  3. Plug the wires into the control board and glue the power pod into the fuselage.
  4. Done! Enjoy flying! On the CG marks, the plane in free flight should glide gently in a downwards slope, and when power is added, it should fly nice and slow with a slight high-alpha configuration.
    PXL_20230728_013741815.jpg PXL_20230728_013313956.jpg PXL_20230728_013743685.jpg PXL_20230728_013755185.jpg PXL_20230728_013753205.jpg
Foamforce
That’s a nice looking design! I’d like to try it but I have a question. The EZ pack v2 doesn’t come with the gray plastic power pod adapter, it’s just the naked circuit board. Do you know if the adapter is still for sale or is somebody has stl plans for it? I couldn’t find it on Thingiverse.
AgentC
Right, I have so many of those pods floating around I didn't even think of checking to see if the v2's had them.
I don't have an STL file, but there's a simple solution: I'll update the plans to include holes for the control board (antenna, LED and on/off switch, and then a simple hatch).
luvmy40
I cut a couple of these when you first posted the plans. I finally got around to building one for my grandson tonight.
I didn't have the plans for the EZ V2 pack so I just modified it on the fly and built it before I looked at the build log. I got the fuse mounted on top of the wing:p, but it glides nicely. I'll try to do a short shake down with it before gifting it to Xzavier.
AgentC
Well that's an interesting take! Let us know how it goes :)
luvmy40
Got out for a test flight today. I think it's just a bit tail heavy. There was a fairly steady breeze, not too stiff, maybe 3-5 mph but constant. She flew down wind fine, but refused to come back upwind. I actually held a helicopter for a few seconds.
I did not peel any paper except for the inside of the fuse nose.
Hi,
Just got around to building and flying it the first time few days ago.
Build was straight forward, but maiden not so.
The isaie I was having is the plane dives down sharply when increasing the throttle above 30%.
Tried to fly it around 6-7 times but the same issue persist even with keeping it slightly tail heavy.
Any help will be great.
Thanks
Hi,
Thanks
Sounds like thrust angle
AgentC
Another thing to try: bend the tail end section up a touch (I do this in the narrow section just behind where the fuselage ends) to add a touch of reflection.
But like the other guys mentioned, a video or photo could be helpful to diagnose any problems.
