I was playing around in Sketchup the other day and modeled an F-15. It quickly transformed into a DTFB model patterned after the FT-22.
I proofed the plans with a build of the airframe. It went together very well.
I have no opportunity to put electronics in it and test it out. I have not even worked out where everything would go. I did calculate a starting point for the CG. A test glide was ok but I could see I was a little nose heavy (that's a good starting point).
(UPDATE): I did some weighted glide testing this morning in larger space. Better starting place for the CG is 1 3/4" forward of where it is marked on the plans. In a bigger space, with longer glides, the original CG marks are too tail heavy. When the plane balanced on a point 1 3/4" forward of the current CG marks, it had a consistent glide that ended in a smooth, greased in, landing. (END UPDATE)
The plane was designed around Ailerons and Elevator (I hope to play with some mixing of those later). Simple bank and yank.
There are two versions here. A prop in slot that would require a 7" prop or smaller (faster motor because the plane is larger than the FT-22). Or, a pusher that will accept a power pod. I was leaning toward the power pod version as the better equipped because a 9x6 prop will fit pretty easily.
Here are some pics of the Prop-in-Slot version.
If anybody is interested in trying one of these out, I would appreciate it. I would like feedback on the plans as well as the plane. The plans are available below. Three separate PDF's for each of the versions. Each PDF is arranged to fit the parts on one sheet of DTFB. Three sheets required. No plans for power pod included (standard FT Power Pod) with the swappable pusher version. Enjoy
F 15 Eagle Prop-in-Slot Fuselage and Front Top Plate.pdf43.3 KB · Views: 31
