Thanks for the quick reply just ideas on how to strengthen the body of the plane and still keep room for air flowWhat do you need help with?
Started to cover the plane using parchment paper and glueF18 build
I'm not sure what the LEX is im not to well up on the terminology
Yes I understand. But to emplmemt them your get into a world of RC I don't know about about i just build them and hopefully fly themLeading edge extensions. Basically slats the extend the wing, and make it more lifty.
No but I seen it done Would be great to have the skillsI don't think lex is necessary in an rc plan.e
No but sure there is no harm in trying .I honestly don't know but if you have any ideas I'm open. Have you any experience with edfs would appreciate some helpjohn 123
Is this your first EDF?
Twin 70 mm EDFs!
By the time you have added the batteries that's going to be quite a big heavy and fast flying plane.
Are you confident you have the skills to handle it?
I have one question maybe you could answer it I have 2 70mm edfs identical. Can I run them off the one ESC the im using is a 60 A ESC and the battery im thinking of using is a 4S 1400 amp or do I have to go back to the drawing board 🤔No but sure there is no harm in trying .I honestly don't know but if you have any ideas I'm open. Have you any experience with edfs would appreciate some help
Thanks very much this is the first time I got it explained to me like that cheers Looks like i need to invest more into the f18 . I will do what you say and hopefully get her airborne if not I have an 800kv brushless motor i could turn it into a prop pusher Thanks again for all your help if you have any more ideas please let me know Hope to keep in contact PS if you have built any jets with EDFs I would love to see themjohn 123
The answer is NO!
The ESC 'reads' the individual pole position of a brushless motor as it passes each magnet to 'time' the next pulse to the next coil. At EDF rpm it is doing this hundreds of times a second. Two brushless motors on one ESC would confuse it completely so they would not run properly, if at all. Each brushless motor requires its own ESC.
To ensure you have the right battery size you really need to know what amps the EDF is drawing. The best way of doing this is to get yourself a Watt meter. It goes between the battery and EDF to measure accurately both the amps and the volts. From this you can work out if the battery is big enough for full power and how long it would be safe to fly for before the battery is discharged to the point of being permanently damaged.
Compared to props EDFs are pretty inefficient so the batteries have to work hard just to fly. Remember this is coupled with 'jet' type airframe that is likely not the most aerodynamically efficient at model speeds.
So selecting the battery becomes a 'balancing act' to have it big enough to provide the power without being over stressed or being too heavy that over loads the plane!
You are clearly a very talented builder Would love to see more of your work. I think I've bitten off more than I can chew so I'm going to put a 800kv brushless motor on it and turn it into a prop pusher iv gone to far to stop now and I want to see it finished. But I still have the two EDFs I have the plans for a sabre so I might build it attest it only takes one EDF so I should be OK I hope . As soon as I start the build I'll post pictures and when I finish the F18 I'll post pictures aswell Thanks again for all your help hope to hear from you soonJohn 123
If you look in the 'EDF Power' section under 'Electric Aircraft' you will see examples of my latest 4 scale EDFs. They are all built of sheet foam and by most EDF standards are really light allowing the use of lower powered EDFs with relatively small batteries.
This my only plane that uses a true 70 mm EDF. It has a 2200mAh 3S LiPo
A single inlet with a long duct that divides into 6 individual exhausts.
Took a bit of experimentation to get it right. The sum of the areas of the exhausts matches the swept area of the 70 mm fan
It is perhaps worth remembering that an EDF is likely to be a much smaller diameter than a prop which means to generate anything like the same thrust it has to push the air out a good deal faster. Not only does this require more power to do but it also means the air inside is travelling much faster than the plane so the shape and smoothness of the duct is of considerable importance. The thrust is only generated at the point the air flow leaves the plane. Any obstruction or even a minor change of direction in the duct will tend to slow the air flow down before it even gets to the outside.
With an EDF the duct is everything both before and after the fan.
