I started off trying to build the FT Versa. I think it turned out well but have never been able to get it in the air. I modified the plans to make it a swappable power pod pusher. If I moved the CG forward it would nose drive right in the ground. move it back 1/8in and it would high alpha and crash. I'm thinking too slow take off speed.
so I figured I would learn on something easier. I bought the speed build kit for the FT sparrow. It glided well, but when I installed my electronics and ballast (5 Steel Carabiners) it would fall out of the sky like a rock. I'm thinking I was too heavy.
https://www.amazon.com/Zinc-Plated-Steel-Carabiner-Snap-Hook/dp/B00JG46FM8/ref=sr_1_1?s=sporting-goods&ie=UTF8&qid=1483234010&sr=1-1&keywords=1%2F4+in+carabiner
Below I'm going to list the electronics I tried to use in both planes. I'm looking for a suggestion of which plane will work best with my gear. Something that is bank and yank 3 ch. and can carry my FVP camera too. 700TVL and Transmitter.
3S 2200mAh Battery
EMAX 2213-935KV Motor
9X4.5 Props
9 Gram Servos
Spektrum AR6200 6ch receiver
Hobby Fans ESC-40A
3S 2200mAh Battery
9X4.5 Props
9 Gram Servos
Hobby Fans ESC-40A
