Hey guys,
I have been a lurker on this forum for a short period and have learned quite a bit. That being said, I still have a lot to learn and wanted to run my ESC/Motor/Battery combo by you all.
I scratch built a plane recently that is similar to the simple storch in design. I am running the following ESC/Motor/Battery:
Motor: http://www.altitudehobbies.com/suppo-motors/suppo-2217-7-1250kv-brushless-motor-park-425-equiv
ESC: http://www.altitudehobbies.com/brushless-esc-bec/suppo-brushless-escs/suppo-30a-brushless-esc
Battery: http://www.hobbyking.com/hobbyking/store/__8851__ZIPPY_Flightmax_3000mAh_3S1P_20C.html
The other day while finishing up my electronics and testing everything I noticed when running the engine for about a 30 second burst it got quite hot. I am wondering if I did something wrong when I paired ESC/Motor/Battery? Or is the engine getting hot normal?
Last mini question or more or less a sanity check. I have the following charger: http://www.amazon.com/Tenergy-TB6-B-Balancing-Charger-Battery/dp/B00466L0BW
I was a bit scared to charge my lipo in fear I would ruin the battery or worst case cause a fire. I bought a battery bag and made sure to charge it while the battery was secure in the bag. I set the volts to 11.1, 3000mah and charged the battery at 3.0 amps. Is this correct?
Thanks guys. Please let me know if I missed anything or you need me to clarify.
