google is your friend
per the spec sheet attached, you need a maximum 2s lipo drawing no more than 12 amps
so the esc is fine, but the battery needs to be 8.4v max (that's 2s, not 3s)
as for the prop required at 2s - a 7 or 8" seems appropriate, but an 8x4 should be a safe bet
indeed, chatgpt says:
The appropriate pitch for an 8-inch propeller on a 2S 2805 2720KV motor would depend on the type of RC aircraft and your performance preferences. Propeller pitch is the theoretical distance in inches that a propeller would move forward in one revolution if it were moving through a soft solid like a screw.
For an 8-inch propeller, common pitch values might range from around 3 to 6 inches. However, the specific pitch that will work best for your setup depends on factors such as the type of aircraft, desired thrust, speed, and the motor's characteristics.
If you're looking for a starting point, you might consider a propeller with a pitch in the middle of the typical range, say around 4 to 5 inches. Keep in mind that you may need to experiment with different propellers to find the one that provides the desired performance for your specific application.
Always refer to the motor manufacturer's recommendations and specifications, as they often provide guidelines for suitable propeller sizes and pitches. Additionally, you can use online propeller calculators to estimate the expected performance based on your motor, battery, and aircraft specifications.
i personally used the 8043 slow fly prop on a few planes, and it is a safe choice i think - not sure a plastic prop is up to the task - you likely need to source a nylon one
and put it on the right way round for the build - the scout is a tractor, the dragonfly was a pusher
