Flexible PCB Board Manufacturing Process
topfastpcb
What is flexible pcb board?
Flexible Printed Circuit Board (FPC), also known as Flexible Circuit Board or Flexible Circuit Board, is a kind of printed circuit board made of flexible substrate material, different from the traditional rigid PCB board is that the flexible PCB board can be bent, folded, twisted, suitable for three-dimensional mounting, the board made of flexible PCB, light, thin, bendable, wider range of applications, can meet more needs. Flexible PCBs are needed in smart phones, tablet PCs, medical devices, aerospace equipment, in-car entertainment systems, sensors, industrial manufacturing, aerospace and other fields, with strong applicability.
Manufacturing process
The manufacturing process of flexible PCB does not differ much from the rigid PCB process, but its substrate and structure are not the same, there will be some differences, and the cost is a little higher than rigid PCB.
Step 1: Cut the flexible copper board into the required size according to the design specifications
Step 2: Drill through holes, blind holes, buried holes and other holes in the laminate to connect the circuits between different layers
Step 3: Deposit a thin layer of copper on the hole wall to realize the electrical connection between layers
The fourth step: the use of light-sensitive equipment photolithography to transfer the circuit pattern to the copper-clad plate for the next step of etching, to ensure that the circuit left after etching is the design required
Step 5: Use chemical solutions to remove unwanted copper foils, retaining the realization of the designed circuit route
Step 6: The surface of the circuit is treated with antioxidant and corrosion protection, such as gold plating, tin plating, or OSP (Organic Solderable Protectant).
Step 7: The overlay film is laminated to the circuit surface to provide insulation, moisture and dust protection to improve the safety and longevity of the PCB board.
Step 8: The layers are pressed together using a lamination technique.
Step 9: Cut the product into the desired shape by cutting or cutting technology.
Step 10: Finished product testing to ensure product quality, after the test is correct, packaging and shipment.
TOPFAST is a professional and reliable one-stop PCB solutions provider for customers specialized in manufacturing quick turn prototypes and small volumes. With high quality and on-time delivery products we won the market's wide acclaim.
My Website: https://topfastpcba.com/
ezbruh
a bit disingenuous with the list of things FPCs are used in because they're usually cables and occasionally have an IC or 2 on them or some passives. They also can't be bent and twisted or folded repeatedly or harshly with any creasing or they will tear or delaminate. Low volume production runs are a nice service for anything though and FPCs can be very useful. Nothing against you or the service but the wording in your post is a bit misleading.
topfastpcb
Thank you very much for your advice.
ethanp
There are many different kinds of Flexible PCB's
  • Single-Sided Flexible Circuits
    • Single copper conductor layer on a flexible dielectric film.
  • Double-Sided Flexible Circuits
    • Double-sided copper clad material with top and bottom cover films. The two conductive layers have an insulating layer between.
  • Multi-Layer Flexible Circuit Boards
    • A combination of single and/or double-sided flex circuits laminated with adhesive onto a single and/or double-sided material.
  • Rigid Flex Circuits
    • Used to accommodate the entire conductor pattern of electric circuit within one component.
If you want to learn more about Flex vs. Rigid-Flex vs. Rigid PCBs & how are they different, you can visit our blog: https://summitinterconnect.com/blog/article/flex-rigid-flex-rigid-pcb-differences/
bisco
i don't think so, but wanted to be sure. i missed the merchants corner, and thought they were a bit off.
thanks!
