Skygeezer65
I have a 20 amp and 35 amp ESC from the Power packs but they did not come with any booklet or instruction sheet. They worked fine at first but both did the same thing. If upon plugging in the battery to a fully setup airplane ( ESC plugged into receiver and motor ) your hand slips and disconnects the battery just after the first few beeps, and you then replug the battery, the ESC is dead and will not respond. Both ESC's did exactly the same thing. Immediate disconnection from the battery kills them. Replacing these ESC's with another one from the drawer shows the system in the airplane working fine. But the Flite test ESC's are forever dead.
Is there an info on these ESC's somewhere on the Flite Test website? I know with other units there is programming with transmitter stick inputs and so on. I have to initiate some of my ESC's to get motor control. But both these Flite Test ESC's were working initially until the quick battery disconnect. Is there any way to revive them? How to you initiate and program these ESC's
