Hi!
Working with customer support, I often get asked what gear should people buy to complete their kit orders.
Well, I'm going to make a list of what we have in the store that's the best match, but feel free to add your own suggestions!
You're going to need a few minimum items.
frame
motors/esc's
props
flight controller
battery
charger
radio system (transmitter and receiver)
If you're doing FPV, you'll need
video transmitter
camera
receiver/monitor/goggles
antennas
So, for the actual systems
The Versacopter:
The Versacopter Frame $59.99
https://store.flitetest.com/versacopter-280-diy-quadcopter
PowerPack E $99.00
https://store.flitetest.com/power-pack-e-racing-mini-quadcopter/
PowerPack E Best 1
https://store.flitetest.com/e-pack-2206-lumenier-2350kv-best-1/
PowerPack E Best 2
https://store.flitetest.com/e-pack-2206-lumenier-2000kv-best-2/
Some sort of Flight Controller, like the Naze32 $20.00 and up (Naze32 is $29.00)
https://store.flitetest.com/naze32-rev-6-flight-controller-board/
You'll need a transmitter and receiver. They range from $99.00 for the very low end, on up. (Spektrum DX6 is $200.00)
https://store.flitetest.com/dx6e-6-channel-dsmx-transmitter-with-ar610-receiver/
You'd need at least 1 battery. This could range from a 3s 1300 mAh, to a 4s 2200 mAh (Here is the 3s 2250 $21.00)
https://store.flitetest.com/lumenier-2250mah-3s-35c-lipo-battery/
A charger that does balance charging, and has a display. $49.00
https://store.flitetest.com/imax-b6ac-pro-battery-charger/
The FT210
PowerPack E $99.00
PowerPack E Best 1
PowerPack E Best 2
You'd need at least 1 battery. You can do either a 3s or 4s 1300 pack
https://store.flitetest.com/1300-4s-60c-battery-by-lumenier/
You'll also need a power distribution board, because unlike the rest of the frames, this one doesn't have it integrated into the frame.
https://store.flitetest.com/matek-power-distributuon-board-xt60-w-bec-5v-12v/
Electrohubs
Electrohub Y6
https://store.flitetest.com/electrohub-y6-kit/
PowerPack D Hexacopter
https://store.flitetest.com/power-pack-d-hexacopter/
Flight Controller
Battery 3s 2200 mAh
Transmitter/Receiver minimum 6 channel, programmable
Electrohub Dragonfly
https://store.flitetest.com/electrohub-dragonfly-kit/
PowerPack D Dragonfly-Pentacopter
https://store.flitetest.com/power-pack-d-dragonfly-pentacopter/
Flight Controller
Battery 3s 2200 mAh
Electrohub Tricopter
https://store.flitetest.com/electrohub-tricopter-kit/
PowerPack D Standard Quadcopter
https://store.flitetest.com/power-pack-d-standard-quadcopter/
Flight Controller
Battery 3s 2200 mAh
frame
motors/esc's
props
flight controller
battery
charger
video transmitter
camera
antennas
The Versacopter:
PowerPack E $99.00
PowerPack E Best 1
PowerPack E Best 2
The FT210
PowerPack E $99.00
PowerPack E Best 1
PowerPack E Best 2
Electrohubs
Electrohub Y6
Flight Controller
Battery 3s 2200 mAh
Flight Controller
Battery 3s 2200 mAh
Flight Controller
Battery 3s 2200 mAh
