Foam Board Das Ugly Stick
Hi Flite Test Crew
I enjoy all your builds have built and crashed plenty its all about the fun of flying Thanks
Please could you look at doing a stick build as this is such a good trainer. also you could look at building a bottom wing trainer similar to the Scanner. For people like me who is still learning to fly
Thanks for a wonderful experience
Edwin
#3
There is also a smaller quick and easy build that flies really well. : http://forum.flitetest.com/showthread.php?14491-(Das)-Little-Stick-Parkflyer-Plans
You can run mt1806 on it but more fun with 2204 or Powerpack "B" sized motor.
Honestly though the tiny trainer will do the trick for learning. This is a little more aerobatic and would be excellent AFTER you have worn out a tiny trainer.
The hotwax version is for sure more polished and uses a symetrical wing but you may appreciate the simple build of the smaller one.
There is a third version that someone posted plans for in an article just a month or so back, so you can look for it.
I want to build a twin stick from the hotwax plans sometime this winter.
