badpilot27
I made a flying wing out of foam board and I found that the upper surface would be offset from the lower surface when I fold the wing. I made the wing in a similar way to the method shown in this video. the offset did make it easier to add dihedral but it would also make it harder to add an extension to the wing which is required for larger wings. I'm wondering if anybody can help me improve my construction method so this doesn't happen on future builds.
I just connected the wings together where the lower surfaces meet and used a piece of foam board to connect a part of the upper surfaces together. the tape is there to cover the hole and it makes it easier to adjust the amount of ballast is in the wing.
