The FX707S is an excellent starting point to motorise. It is aerodynamically pretty efficient to start with
My own conversion is to a true motorised glider with a carefully faired in motor with a folding prop and even more important big flaps.
The other modification include a one piece wing but still held down by the original bolts. The fin and tail glued in place saving the weight of the original plastic fittings and screws.
The 24g LE2204 has a printed motor mount glued to the cut off nose.
A printed cowling matches the fuselage and the folding prop spinner. it includes a small cooling air intake.
The 10A ESC is mounted on the outside of the cockpit to ensure good cooling.
A Lemon 6 channel DSMX Rx is in the somewhat hollowed out cockpit.
All the servos are micro 3.7g type. The four flap and aileron servos are buried in the wings. The elevator servo is cut into the fuselage just behind the cockpit with nylon pull/pull lines back to the elevator. The rudder is fixed.
The ailerons have quite significant differential (more up than down) that virtually eliminates any adverse yaw.
The flaps have 3 positions 0,15 and 50 degrees. There is also an appropriate elevator compensation mix.
It flies very nicely and with a 1500mAh 2s it has an power on endurance approaching 30 minutes.
No thermal condition yet in the UK!
