mad_milchmann
Hi there,
since it's much harder to get Foamboard in Germany and they usually sell it in different sizes and qualities than in the USA you need some additional Informations if you want to make some of the awesome FT Scratchbuilds yourself.
There are a few threads on this already but the Information is quite scattered around in the FT Forum and the rest of the mighty Internet.
So i wanted to start a Inforamtion repository where we can gather Informations which make it easier for fans from Germany (and maybe other european countries) to get the Foamboard they need in the right size and quality (maybe even for a decent price
I started to look for Information a few days ago and already got some, but it is for sure more than incomplete.
If you have additional Information just post them and i will update the first post.
Places To Get Foamboard
online
8....
Isopor makes a variety of foambords, but sells only to companies. It may make sense to ask them for a vendor in your area.
Sizes of Foamboard
Since the FT guys don't talk much about specs (at least in the Episodes I already watched) it's hard to get Information on the Foamboard the use.
In his Article where he compares foamboard rcspaceflight gives us some Informations on Dollartree Foamboard which help us.
Sheet size: 20" x 30" x 3/16"
Total weight of sheet: 115grams
3/16" = 0.47625 (so 5mm Foamboard which we get here should be fine)
20" = 50.8 cm
30" = 76.2 cm
a common size in Germany seems to be 50 cm x 70 cm which should work with some minor changes to the Scratch Build Plans.
Another vommon size seems to be 100 cm x 70 cm wicht leaves some spare foamboard for repairs
Other Informations
KAPPA Foamboard
Foamboard weight comparison
online
- https://www.architekturbedarf.de/
- https://www.modulor.de/
- www.ideeshop.de (sells the lightweight XPS Foamboard)
- http://www.boesner.de (search for "Modellbauplatte" 50x70 2,39€; 70x100 3,93; they just ship 10 or more boards)
- http://www.foamboarden.de/
8....
- http://www.schoergers-papierkiste.de/ (München behind the TU, 500x700x5mm ~2,70€)
Sizes of Foamboard
20" = 50.8 cm
30" = 76.2 cm
Other Informations
KAPPA Foamboard
- I read in another Thread that the Foamboard called "Kappa" is made with cardboard instead of paper and therefore is to stiff to be bent well.
- Also It is made of Polyurethan (PUR) which is 80% heavier
- leightweight Foamboard is made of XPS (Extruded Polystyrene)
- There's also Expanded Polystyrene (EPS) which has a more coarse structure (it's known as styrofoam).
- FoamWerks Tools are sold by Boesner and modulor
- X-Acto foam cutters are sold on amazon --> they seem quite awesome since they can cut 90°, 45°, and v-cuts
Brand | Height | Width | Surface | Weight | Weight/m² |
Dollartree | 508mm | 762mm | 0,387m² | 115g | 297g/m² |
Foamboard.at | 594mm | 841mm | 0,5m² (A1) | 275g | 550g/m² |
