speedbirdted
Doing this for a friend. He wants to try a tissue paper covering job, but is quite pushed for time by work and other projects to build it himself. So, he passed it off to me. This whole quarantine thing has me absolutely stuffed with free time, so I of course was happy to...
Here's what I'm working with. I'll be making a couple changes right off the bat, mostly for RC control. He gave me a little UMX board to work with, and turned sideways it does fit. Also, nowhere local to me sells balsa sheet light enough to make a tail out of, so I'm going to be drawing up my own plan for stick building it.
Speaking of the balsa. My LHS' balsa selection is usually crap. So bad in fact that the minimum-wage employee in charge of restocking the balsa selection restocked it with... basswood. All of it. So no use there either. But I've got a trick up my sleeve called a balsa stripper! And I've got some sheets of 3/32 balsa that's not quite contest grade but it's darn good. All the sticks used in this build have at least one dimension of 3/32, so this should be pretty easy.
All I have done for now is the fuselage sides, which went together easily (and I also which I stupidly forgot to take a picture of before I went to work, oops) Honestly if you need a balsa stripper, just build your own. It's what I did and it hasn't let me down so far.
This is gonna be a really fast build, since I have no covering to do. But, I'll send pictures of it when the other guy does his part of the build
