FT Float Scaling for Mighty Mini's
Byrdman
Good morning! I'm thinking of putting some of the Mini's on floats, or scaling up some mini's for floats, and was wondering if anyone has scaled down the Simple Series Floats to do this and what % worked best.
Just taking the Scout vs the Mini Scout, the length is approx 62% and the wingspan 64. I was thinking if I scaled down the Simple Floats to 65% it would give a little room for error and probably be the size for the Mini's. On any scaled up versions of the Mini Series planes, I can start with the 65% file and scale up accordingly.
Am I thinking this correctly? Would anyone do anything different?
#2
That sounds right to me. A long winded way of probably getting to the same number would be measuring the length of the float vs the fuselage of the full size version (like if you have one you already like) then coming up with the same length for your mini. Will the weight scale down with the height at the same ratio?
Byrdman
Yeah I thought of that too. I have some that are the right size for the smaller Simple series and bigger ones for my Storch that will also probably work for the Legacy and any scaled up Simple Series planes.
I really want to scale up a Simple Stick and put it on floats like they did in the FT video. I wish they would give an equipment rundown and sizing information when they do those videos.
#4
I have thought of a 125-150% stick with one of these bad boys.
https://www.hobbypartz.com/96m601-bigfoot10-2820-1100kv.html
Although i may end up just building a noob tube.
Byrdman
That is a big heavy motor but would be great with all that power! I have a 3536 1000KV on my Storch with a CF 10x5 prop and it pulls it around very well. I plan on using this motor when I build my 125% stick. I may even use @The Hangar 's flat bottom wing design with it instead of the FT wing and put it on the bottom of the fuse instead of the top. If we are going to mash it up, let's do it right!!
