After getting everything put together on my new Gremlin build, I ran into a setup problem using the BetaFlight Configurator 10.2 Chrome app. The Spektrum receiver is bound to the Tx and from what I can tell the FC is functional because I can manipulate the Gremlin and see it moving on the configurator setup tab. I followed TJ's steps for configuring the receiver setting for Serial and enabled UART3 . But the entire time this is going on, the FC is steadily flashing red. I can't find any troubleshooting information describing what this means.
The other problem I have is on the receiver tab of BetaFlight. I set the Channel Mapping to Spektrum and hit save. Now here's another thing I can't find any information on. The status bars for the stick inputs for Yaw, Pitch, etc just blink constantly. Moving the sticks does nothing. All the bars blink in unison. When I go to the Modes tab, assigning a switch to Arm does nothing either.
Can anyone help me out here and tell me why my FC is blinking red? It's not rapid. It's just a steady on/off pattern. And why the stick deflection bars all blink on/off in unison? I would be nice if there was some kind of troubleshooting page for these things explaining what the flash patterns mean. Like computer beep codes. I really hope I don't have to take this thing apart because there are two layers of two-sided tape between the receiver and FC and pulling that off is going to be pretty hard.
In hindsight, I should have done all the configuring before finally assembly just in case something went wrong. At this rate, it will be tough to flash the FC because like I said, that receiver is stuck on there pretty good. That darn 3M tape.
