Battery800
So for me, since I am assuming you use a futaba, that would be 1 and 5 channels for me. But how would I use channel 5 since it only a 2 pos switch? Or are you saying I use differential thrust with the rudder?I used 2 separate channel (ch3,ch5) for my twin motors and I adjusted rudder mix / aileron mix and each can activate/deactivate by toggle switches. You can not imagine after I did that, how much better control I got.
If I once want to make 3motors version I definatelly will use another separate channel (e.g. ch6 ) and the middle (nose) motor will controlled directly by throttle, but another two on the wings are will be at least throttle+rudder mixed or better if throttle+rudder+aileron mixed..
