FT Spitfire CoG - Centre of Gravity
Anyone got a spec for CoG/ Centre of Gravity on the FT Spit? I could not find one on the plan. Did maiden it with a 2200 stock but she kinda flew like a ski jumper. Suspect coz in uk we have to use 5mm she is tail heavy as there is 20% more weight. Interested to know what stock CoG is tho so I can match that with weights as necessary. Can get there myself in the end but want to know. Tks,
Kenbow
#2
The center of the spar should get you close. May as well fly a bigger battery if you have to add nose weight. Good luck, the FT Spit flies fantastic!
