stay-fun
Helicopter addict
Hi guys,
Here's a take on an FT style autogyro! After numorous crashes of my Auto-G from HK, I decided to make a new fuselage for it, FT style. I took the dimensions from the HK fuselage, and made the FT style fuse.
I changed the dimensions of the vertical stabilizer, but kept the total area the same. The height of the rotor is even a little higher, 2 cm or so, so the rotor won't hit the tail (which had happened a couple of times with the HK fuse).
Also, the advantage of the FT style fuselage is battery placement! There hardly is any room for the battery in the HK fuse, and an autogyro generally needs to be very nose heavy, so I was flying with down elevator a lot! Now I just mount the battery outside the fuse, all the way up front and it flies even better than the orginal! In my view . Although the rudder authority seems a little less, because the whole fuselage acts as a vertical stabilizer. The original simply had an aluminum tube as tail. See pics and video:
Electronics setup:
9 gram servos on elevator and rudder
Hitec HS-5065MG on aileron (tilt rotor, more power is needed)
Align 35A ESC
sunnysky V2216-12 800kV motor
4s 1300mAh battery
10x8 GWS prop
Electronics setup:
Align 35A ESC
4s 1300mAh battery
10x8 GWS prop
