CptCrazyFingers
I bought the Turbo Gremlin with the DSMX receiver and had it built by FT. After figuring out how to connect my FPV goggles and how to bind my transmitter to an auto-binding receiver that was not auto-binding, I am now at the point where the quad will not arm. The transmitter I am using is the Spectrum DXe. I plugged the quad into Betaflght, calibrated the accelerometer, ensured that my transmitter is connected and all the stick movements are doing what they should be doing, centered all trims, and successfully tested the motors with the throttle sliders in Betaflight. I even tweaked the lowest throttle limit, moving it above and below my transmitter's lowest throttle reading. The DXe has an arm switch but I don't think its being used. My Aux 1 switch is set in Betaflight as the arm switch and when toggled, the indicator moves into the armed range. My arming disable flags are 4 and 16. I looked these up and 4 is a flag the indicates that the arming switch is off. I have toggled every switch on my transmitter and this flag does not go away. Flag 16 is just there because my quad is connected to Betaflight. Does anyone have any suggestions?
