DennisSwe
I'd go for 3mm depron, with a layer of tape or shrink film on the outer surfaces to stiffen it up and make it more robust.
You'll have to construct it a little differently though - for instance, you can't score uncovered depron and fold it in half for the spars, since it will just snap. You'll have to cut out the 2 spar halves seperately and glue them back to back. Scoring and folding the wing curve should work okay though.
Also, the lack of outer paper layers will make it a little less rigid. You probably should consider putting an extra depron spar in the wings, or maybe sinking some thin carbon rods into the underside of the wing across the joint.
On the plus side, it will probably end up being slightly lighter than the equivalent foam board aircraft.
I tried to use the 6mm first, but I didnt have any good sticky tape for det front leading edge.
So then I used 3mm depron for the top side of the wint, worked good...but now I have very flimsy elevons.
Will try to glue a second 3mm on them and hope it will stifffen it up good, and I´m going to tape the whole wing for extra stiffness.
Later today I´ll be finishing it, hopefully it will work good.
I´ll post some photos later.
