FTFC25: Build-ruary by Mr Man
FT Goblin Build Log:
Printed and stitched together plans.
Do’s and Don’ts: Do cut out the spar further for the servo, as it will sink in more reducing drag and will increase ease of assembly.
‘Started on wings. I sunk the servos down further so they are flush with wing.
Fuselage assembly.
Everything is now dry fitted.
Alright! Nose made and everything glued.
I’ve got a 70a bi-directional esc in there.
There’s a Detrum 2815 2700kv in the fuse.
MS Gee Bee by @Mr Man ,
Do’s and Don’ts: Do hunk out some foam where the aileron servos go, otherwise it won’t work, Don’t glue anything in upside down like I did, I had to cut it off and redo it.
Internal structure
Tail feathers glued together
F6 former cavity shown.
Tail feathers glued on.
Elevator servo installed
Skins started
Skins glued on.
Picture of rear skins.
Canopy glued on.
Wing started, spar in.
Servo cavity.
Both servos in.
Wing glued on.
All pushrods in (not pictured)
@Grifflyer Hotliner.
Printed and stitched together plans:
Do’s and Don’ts: Do use two servos for the wing, just hunk out some foam so they are flush, Do install the elevator servo in the bottom of the fuselage, it makes it very accessible. Don’t use one servo for the wing like I did, it made it very difficult to install the battery.
Fuselage glued up.
Horizontal stabilizer on.
Elevator finished.
Starting on wings, that’s a fiberglass spar from a kite.
Fuselage finished, I needed to custom make front nose top piece, as well as motor mount.
Wing finished as well, I used the chart below to figure out single servo ailerons.
It’s finished! Just needs paint.
Mini Arrow build log.
Spars built, interesting how everything is an A folds in this.
Do’s and Don’ts: Do install the receiver inside the wing spar, as it will free up a ton of room in the fuselage, Also, cut out a hole for esc and glue it in, it will have amazing airflow. Don’ts, Don’t forget to cut out the small hatches in the underside of the wing.
Wings joined, I’m starting to like the arrow!
Spars in and wings glued down.
Centerpod installed.
Electronics in.
FT Spitfire with speedwing.
Motor compared with power pack C equivalent.
Do’s and Don’ts, Do add a speedwing, your performance will increase drastically, and also upgrade your spar with the one @nerdnic uses in his planes, Don’ts: Don’t glue the wingtips till last.
Fuselage started.
Formers and wing.
Speedwing mod.
A closer look.
Servo cutout.
Swappable power pod.
That’s the gee bee, didn’t work, any ideas for a new plane? (Preferably Extremely fast)
I’m running a 3536 and a 60a esc, a 10x7 prop FOR STARTERS.
