FTFC25: Build-ruary by Patriot Rc
Patriot Rc
Next I glued on the doublers.
Then I folded the fuselage together.
Next I built the canopy.
Then I beveled the Elevons.
Next I added the sidepanels, servos, hooked up the servo linkages and put on the linkage guides.
Then I joined the fuselage to the wing.
Next I added the motor, ESC and gyro.
Patriot Rc
Then I added the belly pan and vertical stabilizers (I added the hatch to get the gyro out when i want it for my other airplanes)
Here is what it look like inside.
Now it is ready for painting.
It took about 2 hours to build.
It took about 15 min (Not including dry time) to Paint
it was pretty easy to build 1 (1 out of 5).
It flew pretty easy 2 (1 out of 5)
Do's and Don't's
Always check the battery before you fly to make sure it is full (I didn't and my brother crashed it in too a tree)
Patriot Rc
Here it is! its done. After I flew it the first time and its adventure in the tree its gotten a little dinged up
Before:
After:
Patriot Rc
Master series mustang build log:
Here are the formers for the fuselage
Here's the nose/fus. section
Here's more formers for the fus.
Here's the tail section of the fuselage.
Here's some pictures of the fuselage.
Here's is the fuselage and the bottom wing skin with the spars (unfortunately I mounted the front nose section upside down on the nose so it looks funny, I am going to try redoing that section by cutting it off with a hot knife and putting a new one on.)
Flying Cherokee
Looking good so far!
Jo's squadron
How many sheets of foam did it take?
Jo's squadron
How is it coming?
Patriot Rc
I'm going to have landing gear, so I put some paint stir sticks on the inside of the wing.
Then I added the top wing skins.
Then I made the scoop.
Next I put on the vertical and horizontal stabilizers and tail fairing.
Then I added the servos and the scoop.
Next I made and installed the canopy.
Then I added the aileron servos in the wing.
Landing gear? That'll increase drag if you want speed.
