Hey, RC enthusiasts
First of all I want to apologize for my English, I live in Belgium so I don 't talk English that often.
Lately I was reading about RC vehicles, especially quadcopters. At first the "information" I 've red was overwelming n what parts you all need en which ones are "good" and which are "bad", but after lots and lots of reading watching YouTube vids it came pretty clear what parts and equipment I needed. So I 've put a list togheter for all the parts that I am planning to use, the main goal is just to build a "cheap" H-Quad for just some flying in the park and maybe a little racing, money isn 't the problem here but it would be a bit stupid to give out 600 - 700 € for my first ever quadcopter that I probably will crash in the first 5 min. of flight
This is my list on every part I think is needed for a quadcopter with FPV ( I know this isn 't the most high-end equipment, because I can always add and/or replace it, I use to start somewhere so just begin at the bottom of the ladder and work my way up)
(eveything will be purchased on HobbyKing)
If you have any suggestion or advice of some kind I would love to hear it.
PARTS LIST
FRAME
- SLICK 220mm Quad-Copter Composite Kit (13.59€)
COMPONENTS
- Hobbyking KK2.1.5 Multi-rotor LCD Flight Control Board With 6050MPU And Atmel 644PA (17.59€)
- Afro ESC 12Amp Ultra Lite Multi-rotor Motor Speed Controller (SimonK Firmware) Version 3 (4x7.99€=31.96€)
- DYS BE1806-13 Brushless Motor for Multirotor (2300KV) 24g (4x7.70€=30.80€)
- Gemfan 5030 Multirotor Propellers One Pair CW CCW (Black) (2x1.05€=2.10€)
- Gemfan 5030 Multirotor Propellers One Pair CW CCW (RED) (2x1.05€=2.10€)
- Turnigy 1300mAh 3S 25C Lipo Pack (3x7.99€=23.98€)
- Hobby King Quadcopter Power Distribution Board Lite. (3.11€)
CONTROL
- Turnigy 9XR Transmitter Mode 2 (No Module) (40.18€)
- FrSky DJT 2.4Hhz Combo Pack for JR w/ Telemetry Module & V8FR-II RX (31.99€)
- Turnigy 9XR Safety Protected 11.1v (3s) 2200mAh 1.5C Transmitter Pack (10.39€)
CHARGER
- Turnigy Accucel-6 50W 6A Balancer/Charger w/ Accessories (18.39€)
- Hobbyking 60w Power Supply (7.99€)
FPV
- Quanum Complete FPV Bundle Set w/ Goggles, 5.8GHz 32ch Video TX & RX, CP Antennas and Camera (PNF) (79.99€)
- Turnigy 2200mAh 3S 20C Lipo Pack (6.80€)
CONNECTIONS + ACCESOIRES
- 15CM Male to Male Servo Lead (JR) 26AWG (10pcs/set) (1.52€)
- 6 LED Strip White (1.52€)
- 6 LED Strip Red (1.52€)
- Turnigy Receiver Controlled Switch (5.80€)
- 5.6mm x 12mm M3 Nylon Threaded Spacer (10pc) (0.69€)
- M3 Nylon Nut (10pcs/bag) (0.55€)
- Turnigy Battery Strap 330mm (2x1.27€= 2.54€)
- D-Buzzer - HobbyKing® Discovery Buzzer (2.35€)
- Peel-n-stick foam double sided tape 10x5inch 4mm thick (0.95€)
- XT60 - JST Female in-line power adapter (1.54€)
Total: 339.20€+ Shipping (77€)= 416.20€
PARTS LIST
FRAME
COMPONENTS
CONTROL
CHARGER
FPV
