Fireflyer
I recently built a gremlin . I have flown it a about 5 times no issues no suddenly it created a roll right that i can't trim out must hold extreme back left until until the right roll increases enough that the gremlin can't be controlled . I have not had any major crashes to cause damage . I have been on the forum trying to trouble shoot this but can't seem to get it to go away.
I have:
Checked and reset all TX/rx in beta flight All center stick are all at 1500
re-calibrated the accelerometer
I went to the motor tab and ran each motor to recheck rotation and isolate vibration
checked that the FC is secure in the frame and not moving
tightened the air frame to eliminate vibrations.
I shut off the accelerometer and pow! flies with a nearly hand off hover
I can also fly in atti mode which does not use the accelerometer.
I am currently flying stock settings on PID , tuning would be done in rate mode I'm not sure this would correct my issue.
Any suggestions would be appreciated.
I have:
