olingoudey
Hello FliteTest Forums,
It's already been a journey to the place I'm at now in building a Gremlin. I realize now that I've been in a little bit over my head starting with a Gremlin.
I'm running into a few problems that I would love some help help fixing. Fixing one major problem might help me solving the next. This is my second attempt at building a Gremlin, so any help would be greatly appreciated.
The first problem is with the firmware of the Femto F3 flight controller. The board does not function correctly after attempts to flash firmware. A red light flashes every second, it's not possible to spin motors with BetaFlight, and the receiver and transmitter do not connect, suggesting the receiver is not properly powered. I'm worried that the FC might be bricked, but it is soldered together properly, and I have only tried flashing the SPRACINGF3EVO firmware, so I don't know why.
I've tried many times to wipe the firmware clean, and flash the right one (3.4.1 - SPRACINGF3EVO). I don't know what I'm doing wrong: First I short the boot pads, and I keep them connected because it's unclear at what point exactly I need to have them jumped. At this point I plug the FC into BetaFlight, and I see that the FC is in DFU mode. Before flashing the firmware, I successfully ran the Zadig application that the FC Manual recommends. I've experimented with this entire flashing process, changed settings in BetaFlight before flashing, all with the same result.
Anyway, thanks for taking the time to read this, I can't wait to get this working. If you have any ideas as to what might be causing this, I'd love some input.
