Gryf
Hi -
I just finished my Gremlin build, and am setting it up in Betaflight using TJ's walkthrough. I've verified that the board is good (meaning, the onscreen "quad" follows all movements of the real thing), and have bound it to my radio successfully. I've set up the appropriate radio specs in Betaflight, but when I power up the quad, bind it, plug in the USB cable, connect, and go to "Receiver" in the Configurator, I don't see any readings for the various channels. See the picture below. Actually, the colored bars appear for a split second and then go away. Any advice would be welcome!
Thanks in advance,
Gryf
[EDIT: Now the USB channel is failing to recognize the Gremlin when I connect it. Argh... Did the board go bad all of a sudden?]
![betaflight.jpg betaflight.jpg](https://ftforumx2.s3.amazonaws.com/2018/01/168971_ccdcb8305d10c16b9de8b6e56ec132e0_thumb.jpg)
Thanks in advance,
Gryf
