Guillows Piper Super Cub RC conversion
Citabria
So I’m almost done building this super cub and it looks like it will fly! Wings are slightly warped like a banana from root to tip but there doesn’t seem to be any washout type warping. I don’t know what my deal is but I can’t make wings look pretty but, I can make a fuselage look decent even though there are far more curves in a fuse than in a wing. I used JB weld for the landing gear and got some bigger tires too because big tires are cool.
Citabria
Battery mount. The battery sits right under the CG
Citabria
Maiden Flight tomorrow morning! Everything looks good! The Cub weighs 6 grams less and has 2 more inches of wing area than my foam 182 so it should be a better flying airplane as long as I didn’t warp the wings a ton.
Citabria
Winds calmed down a little bit so I did some test glides which were hit and miss. Most of the time it glided fairly straight. So I did a little maiden in my backyard and it seems to pull real hard to left due to p-factor and stall out. I think I’ll have to trim it a lot.
Citabria
Well that’s the end of that.🤣 I actually got it to fly but it was so out of trim that it got pulled into some rocks.
