Turns out I did have it plugged into the wrong recover channel. I would of sworn it was correct. Another question I am using a S6R reciver and I did not calibrate it yet I was just hopeing to use it as a 6 channel reciver. Only sometimes the esc calibrate and I can't figure out why only sometimes it calibrate.
Thanks for the help
I'm not sure what you mean by calibrating the S6R receiver...As far as I know, there's no calibration to be done on the receiver itself to get it to work with 6 channels; they should all be working and you just have to connect something to the channel and then set it as active in your setup on the transmitter - i.e., you want to set up flaps on one channel, so you plug the flap servos in on channel 6, and then tell your transmitter that Switch A is set for flaps, and that they're connected to channel 6 on your receiver. Then, when you flip Switch A on or off, the flaps turn on or off.
That's just one example of using the additional channel...
