Solved FT Guinea pig thrust cuts out
Zjensen
Just got done with the guinea pig speed build kit with twin power pack, and am having problems with one of the motors cutting out at full throttle and the other motor has a delay. Both ESC’s are plugged into one channel with y-harness. Would greatly appreciate some help
Zjensen
Need to calibrate the ESCs. Unplug the plane. Turn on transmitter. Put throttle at full. Plug in plane. Wait for a couple beeps. Turn throttle all the way down. Wait for normal ESC startup beeps. Profit.
Thank you very much, I will try this, I didn’t know that you had to calibrate the ESCs
Bricks
Did you remove one of the red power wires plugging in to the Y cable so only one ESC is supplying power?
