The Naza will fly on a Knuckle frame. The Naza is a very docile controller, limits the envelope of performance dramatically versus a KK2, which is very smooth and easy to learn on; only down side is that it wont be very fun to throw about.
Pair the Knuckle frame with the following power plant, and you're in the air for at least 10 minutes with plenty of lift for a go pro and FPV hardware.
Remove the red wire from the ESC's servo connector when plugging into the Naza controller; it doesn't need the 5V power as it gets its power from the auxiliary module with the status LED and USB port.
