Naza -M Lite not being recognised (WIN 10)
stereodreieck86
Hey guys,
I recently bought an F450 Copter for next to nothing with NAZA-M LiTE.
The Copter is not being recognized by the Hardware Manager, I can not install the DJI Driver (even though I am the Admin), and even the WIN 10 Troubleshooting (execute unsigned driver) does not work as you can see in the video. The video is in German.
Cheers
Nik
Aireal Anarchist
I cant speak to the M Lite specifically....however I had the same problem last week with the NAZA M version with this KNOWN ISSUE while trying to setup a Tarot 680 hexacopter
I finally contacted the manufacturer and they sent me a windows file to paste into the systems folder with installation instructions....
contact them and explain your issues....good luck
stereodreieck86
It was not a Driver issue! The solution in my case was simple: I set the Date to 2013! and everything worked just fine.
VERY plausible :-D. ALL new old-stock clearance parts...
The firmware was already hacked up to non-lite version.
More than likely the only DJI I will own other than I have a DJI Flamewheel Hex 550 frame too. It has been thrashed quite a bit with non DJI hardware. Even used to FPV it on 6S packs.
LB
