HeadPlay 800 x 600 FPV goggles, 5.8g 200mw Wireless Tx/Rx, 1/3 SONY CCD Video Camera
dezertdog
Sold as is, as pictured, like new condition (never flown) $269 shipped for the HeadPlay and $39 shipped for the Tx/Rx/Camera. OR $299 shipped for the combo.
All power wiring and channel setup is pre-configured to "just work" when plugged in, bench tested as shown with great video.
HeadPlay System
(1) Visor (goggles)
(1) Liberator (video processor)
(1) Liberator protector (red case)
(1) Li-poly Turnigy battery 2650mAh
(1) Noise reducing earbuds
(1) A/C Power Adapter (US plug type)
(1) S-Video / Composite (AV RCA Adaptor)
(1) Storage Case
(1) Media USB Key
(1) Visor lens cleaning cloth
(1) Cushioned Visor inserts
(1) Owners Manual
5.8ghz 200mw FPV Wireless AV Tx & Rx Set
Good for up to 500m flying with the supplied antenna. Unit includes built-in microphone. Receiver unit has additional AV outputs for video recording while using FPV goggles.
Output impedance: 50Ohm
Output power: 21~23dBm
Channels: 8
Transmitter operating voltage: 7~15VDC / 150mA
Receiver operating voltage: 5VDC
Operating temp: -10~85C
Video bandwidth: 0~8.0MHz
Audio frequency: 6.5MHz
Video input level: 0.8~1.2Vp-p
Video input impedance: 75Ohm
Audio input level: 0.5~2.0Vp-p
Audio input impedance: 10K/Ohm
Weight: 25g
Antenna connector: SMA
Dimensions: 55x26x17mm
Channels (5.8ghz): 5705,5865,5665,5645,5885,5905,5925,5945MHZ
1/3-inch SONY CCD Video Camera (NTSC)
1 x SONY CCD 1/3inch Camera
1 x Wiring Loom
1 x Lens cap
Pixel: 752 x 582(NTSC)
Internal synchronization
Horizontal resolution: 520TV Lines
Minimum Illumination: 0.1Lux/F1.2
S/N Ratio: Greater than 48dB(AGC OFF/B/W OFF)
White balance: Auto Tracking White Balance
Auto backlight compensation: On/OFF switchable
Lens: 3.6-6mm
Input voltage: DC12V
Electric current: 80MA±5MA
Electronic Shutter: Auto
PAL: 1/50 to 1/100,000 seconds
Video output: 1.0Vp~p75Ω
Operation Temp.: -10~+50?
Size: 38 x 38
Power supply: 12V/150mA
