adamjames1998
Hi, ive recently built my quad and i am having some little problems with it, when i set it down on the ground and increase the throttle so its 'idling' one of the motors continually increases and the opposite one will decrease, as if it is trying to level out, however i have calibrated it on numerous occasions and used different firmware all with the same results, when i increase the throttle for take off it rolls to the right, I can correct this using the roll stick but to do this every take off is quite annoying as when the quad is in the air it has no problems leveling and is perfectly balanced when in the air. I was hoping someone could help me resolve this problem thanks
Adam.
Radio:
Turnigy 9XR PRO Radio Transmitter Mode 2 (without module)
Turnigy 9XR Safety Protected 11.1v (3s) 2200mAh 1.5C Transmitter Pack
FrSky XJT 2.4Ghz Combo Pack for JR w/ Telemetry Module
Quadcopter:
S500 Glass Fiber Quadcopter Frame 480mm - Integrated PCB Version
CC3D Atom OpenPilot Flight Control Board Authorized (flashed with LibrePilot)
AX-2810Q-750KV Brushless Quadcopter Motor
HobbyWing X-Rotor ESC 40amp OPTO
HobbyKing Thin E-Prop Propellor 10x5
X8R 8/16Ch S.BUS ACCST Telemetry Receiver
Turnigy Graphene 2200mah 3s 45C Lipo Pack XT60
Adam.
Radio:
Quadcopter:
