This is my first foray into FPV flying so it's likely I'm the cause of the problem, but I can't sort out what the solution is. I built a small wing (the mini arrow) with the following components:
Battery: https://store.flitetest.com/lumenier-1000mah-3s-35c-lipo-battery-xt60/
Motor: https://store.flitetest.com/emax-motor-mt2204-kv2300/
ESC: https://store.flitetest.com/blheli-series-12amp-esc-xt-30/
Receiver: https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=91061
Trans + Camera: https://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=81335
The transmitter and camera rig are powered via the balance lead from the battery. As it stands, when I power everything up the video is clear. And if I test throttle with no prop attached, the video also remains clear all the way up to 100%. However, once I have the prop installed, I get full video loss past a certain throttle threshold (unfortunately this threshold is much lower than what's necessary for flight). The video isn't somewhat obscured, the feed goes to full blown static and only reappears once I throttle back down. I understand that there can be interference caused from the ESC and motor power, but I'm not sure if this is the case here. There's some interaction with the lead going from the ESC to the receiver (at moderate throttle the video occasionally appears if I move the cord, but the behavior isn't very consistent). If that is the cause of the signal loss however, I'm not sure what the appropriate fix is. Appreciate any advice or troubleshooting tips and can post some photos of the setup if that helps at all.
