Starter questions:
Is this the .40 size GP J-3" 76 Wingspan?
What size engines do you have? Maybe post photos. Are they new or used?
You probably want to bench run them, and break them in if they are new.
If they are used you get whatever break-in the original owner gave them.
What size props do you have for the engines
Get some fuel, make sure you have good charged batteries in your glow /charger/igniter. It can be really frustrating if your charger/igniter isn't charged enough.
Let us know what you have for engines and what state they are in, we can offer more advice.
As far as building you will need a flat surface + Titebond, CA, and maybe epoxy adhesives. Sandpaper, sanding block. X-acto #11 blades knives. X-acto saw blades very helpful.
People use inexpensive Luan doors from HD, Lowes as building surfaces. Maybe use a sheet of pink foam from HD / Lowes on top of the door. Foam has to lay flat to get straight/flat wing and fuselage. Use T-pins to hold your balsa down on the plans - use plastic or wax paper over the plans so they don't get glued to the plane pieces.
Keep us posted -
Poughkeepsie Pete
