Hi guys. I used to consider myself pretty good at tuning stuff. This one has me confused. Its a Rcexplorer tricopter v3 and t motor 2216 930kv motors running 4s and 8040 props. Here are the PIDs at the time of this video
set p_pitch = 44
set i_pitch = 26
set d_pitch = 25
set p_roll = 47
set i_roll = 30
set d_roll = 25
set p_yaw = 200
set i_yaw = 20
set d_yaw = 33
set roll_rate = 55
set pitch_rate = 48
set yaw_rate = 60
set tri_motor_acc_yaw_correction = 0
set gyro_soft_lpf = 90.000
set tri_dynamic_yaw_minthrottle = 200
set tri_dynamic_yaw_maxthrottle = 70
Here is a link to a video
https://youtu.be/7L36ir8hLV0
Basically it has a slight wobble that I cant tune out. No matter what I do it still shakes slightly. I have tried p gains as high as 7.0 and as low as 3.0
My ESCs are HK20a flashed with SimonK.
Any help would be much appreciated.
Paul
set p_pitch = 44
set i_pitch = 26
set d_pitch = 25
set p_roll = 47
set i_roll = 30
set d_roll = 25
set p_yaw = 200
set i_yaw = 20
set d_yaw = 33
set roll_rate = 55
set pitch_rate = 48
set yaw_rate = 60
Paul
