Hot wire templates
Site Moderator
Does anyone know where you can find templates for hot wired rc planes?
Thank you!
I make mine from plans, take any set of RC plans and make a template to cut the parts. You can use wood, laminate even formboard to make the templates. With foam, you need to cover the foam where the wire will ride, with aluminum tape, the stuff used to seal air ducts. After you apply the tape, you will need to smooth it out with a screwdriver or something similar.
agupt108
Where do you get those plans from? Thank you!
