Maybe, I don't know.
You are making this much much harder that is needs to be. Take an old 5v transformer, the kind that plugs in to a wall outlet, I call them wall warts. Get the largest one you can find, the big ones provide more amps. Take a board and put a couple of screws about a foot apart. Then take a thin wire and attach to the screws, attach you transformer to the wire.
5V and 1 amp should be about right for a foot of thin wire, about 26 gauge.
Here are 3 of my hot wire bows. They are nothing fancy, the small one, top left, has about a foot of wire and runs off of either a 5 or 12v wall wart, can’t remember which. This is the one I use the most often, it just easer to handle. The bottom one has about the same cutting wire but is long reach. I use it to break down 4x8 sheets of foam. I have another with even longer reach, not pictured. The long bow, top right, is used for cutting wings, runs on 24v.
I have other cutters that are for forming things, it used much thicker wire, about 16 gauge, it runs on 2V but 50amps. It's great for hogging out servo holes. Just bend the wire to the shape you want and cut away.
As I said before, Get the voltage about right then use a simple dimmer switch to power the transformer. Dial the heat in with the dimmer.
