how many deg. are the control surfaces on the old Fogey supposed to be.
S superchamp Member Oct 31, 2013 #1 how many deg. are the control surfaces on the old Fogey supposed to be.
xuzme720 Dedicated foam bender Mentor Oct 31, 2013 #2 I don't know how many degrees it is but it should be from 1/2" to 3/4" of throw.
NewZee Member Oct 31, 2013 #3 Also not sure about degrees, but the Spitfire on low rate is about 30 degrees. if you're using the Fogey for beginner (trainer) like me, make sure to use Expo, and dual rates, and restrict tral of servos a bit.
