Velojet
I'm building a Mighty Mini Old Fogey but have found that the Maker Foam kit parts have shrunk so that edges are now a U-shaped groove instead of a flat cut (see pictures).
(The parts have been stored and handled in normal temperature and moisture conditions.)
This shrinkage causes two problems, one for the build and one for flying:
1) In the build, it means that glue adheres only to the outer paper covering, seriously reducing strength.
20 In flight, I anticipate that the grooved edges of the flying surfaces will reduce lift and at worst cause erratic performance.
What do you advise me to do to deal with these problems?
Thanks!
Thanks!
