Jude Schauer
The problem with that design is that the roll axis did not have the RPM induced torque leveling. I was able to get the roll PIDs stable, but there wasn't a whole lot of control bandwidth as there was no impact of the RPMs on roll axis, and the moment for increased thrust impacting the roll axis was pretty small as the rotors were right next to each other. I also did not have the capability to translate left/right while remaining level.I think you could pull off a configuration like in your flight attempt video which works for control of roll/pitch/yaw, but also have the rotors braced on both sides. Kind of having the airframe wrap around the rotors like a cinewhoop.
You'd take a weight hit on the frame structure, but the added stiffness I think would let you push the cyclos to higher RPMs for more thrust with all your planned upgrades
I think this is what I'm going to go with. I have to mess around with the spacing/frame a little bit but the general layout is there. I'll have to build two additional rotors, but the overall design goal that I'm going for is maneuverability and thrust to weight. This should be the best design that would allow peak maneuverability without going up to 8 rotors? I'll also be able to extend the frame out pretty easily to wrap around. Might be good to move the two independent rotors inside the frame? I'd have to put electronics on the outside but that might be the move.
That would be sweet, but the moments and control coupling would probably be way too high. Might be doable though if a creative guy like Nick would try.Cool progress. Its always interesting to see.
I am trying to imagine if it would be possible to build a big single free rotor cyclocopter driven by props like Nick's giant flying ceiling fan. Driving a fuselage and the linkages in pitch instead of yaw. Maybe drive that fuselage framework from both sides and twist the blades of the rotor for roll? Just dreaming...
