Hi,
I am having an issue with a Bixler build. The plane came with a faulty servo so I had to replace it with a HXT-900 servo that i had lying around.
The problem I am having is that the HXT servo now goes to the extreme right when I connect the battery to the receiver and I am not able to move it at all with the TX. After a while the servo becomes quite hot as it seems to be holding the extreme right position.
I have tested the servo on all channels on the receiver and the behaviour is the same. I have also tested a second HXT and it shows the same issue.
All other servos that came with the plane seem to react and work fine.
Once I disconnect the power the servo seems to move freely.
My TX is a Turnigy 9x with a FrSky DJT module and the receiver is a FrSky D8R-II PLUS.
Does anyone have any idea what can be at fault here ?
Regards,
Kristjan
Regards,
Kristjan
